10-17-2013, 02:31 PM
Strange loud "whirring" noise on startup?
115K 4x2 v8
When you start it motor makes a loud whirring noise for 20 seconds or so than it stops. Sounds like a electrical motor or a fan of some kind. Best guess it sounds to be coming from middle of motor like in the intake manifold. Truck runs and drives fine no CEL.
Search did not help because I don't know if i spelled "whirring" right.
Thanks
10-17-2013, 02:40 PM
Originally Posted by IcantDo55
115K 4x2 v8
Thanks
Follow up:
I typed this after changing oil and it was the 1st and 2nd start up while cold. I had truck idling while I posted this, went back outside turned it off and on and no noise. Just posting whit I see.
10-17-2013, 02:43 PM
This may sound stupid but, do you have XREAS on your Rig?
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
10-17-2013, 02:44 PM
Thats the corner to corner shock thing right? I dont believe the 4x2 came with that. Why?
10-17-2013, 02:48 PM
Real Name: Matt
Real Name: Matt
115K 4x2 v8
Thanks
What year is your 4Runner? Sounds like it's the air pump system going bad. I had the same thing but installed a bypass module to fix the issue.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
Ah okay, because if you did, that would be something to look at(Process of elimination). I say this because sometimes I can hear this whirring noise, which happen to be the XREAS doing it's thing.
PS: Sorry, I didn't catch the 4x2 thing from the get go..
10-17-2013, 02:49 PM
Yeah, the emissions pump system.
10-17-2013, 02:50 PM
2006
I like bypasses.
Where is this pump? Can I default it on to see if its the sound and how?
2006 4x2 Limited 115K
Broken sunroof, like the rest.
10-17-2013, 02:51 PM
This is the engine fan.
During start up you get a big whirl sound because the fan comes on and then after a few seconds stops.
My Tacoma did this too.
Completely normal.
2009 Trail Edition - ICON lift, Total Chaos UCA, BF Goodrich Mud Terrain KM2 285/70/17's, SCS Stealth 6 Matte Gunmetal finish, K9 2.2m Roof Rack.
10-17-2013, 02:53 PM
Completely normal.
This is really loud. Had truck for 6 months I think I would have heard it before.
10-17-2013, 03:00 PM
Real Name: Matt
Real Name: Matt
2006
I like bypasses.
It's located UNDER the intake manifold, so a proper fix is expensive. There are a couple bypasses: cheap one involving a relay, resistor and some wiring, or a $200 solid state module that tricks the air injection system into thinking conditions are such that it should NOT run (keeps it in stand-by mode), and then there's the whole top engine tear down to replace a couple expensive pumps and air valves.
What it is
Brief whirring/revving noise at startup
module and a good read on why/how they fail
Let me know if you have any other questions. I know another member here did the relay/resistor method which works just as well as the module.
@ superman3043
Bottom line is that you can also just live with it, but it can/will throw codes depending on which part of it has failed and certain codes will throw the vehicle into limp mode (rarest side effect but still a possibility).
It will only activate when the engine is cold. Which is why when you went back out and fired up the truck again it didn't activate. Not sure if you have a scantool or not but might want to do a OBDII scan or stop by a parts store that does complimentary scans. It might turn up a pending code.
10-19-2013, 01:39 AM
What it is
@ superman3043
Excellent post sir. Will report back after fix
10-19-2013, 01:49 AM
10-19-2013, 05:15 AM
Completely normal.
mine does this too...........guess its normal..opened the hood to confirm, its the fan alright
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
10-23-2013, 06:17 PM
I read in one of the many searches I did that you could unplug the pump. Where is the plug?
