Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 12-22-2008, 06:27 PM #1
thetaxguy's Avatar
thetaxguy thetaxguy is offline
Member
thetaxguy is an unknown quantity at this point
Member
thetaxguy's Avatar
Winch install w/o aftermarket bumper
I am looking to install a winch on my 2008 UR, but I just do not want to replace the entire bumper cover. If at all possible I would like to install a winch behind the front license plate. If a little cutting is necessary I would not be opposed to it. If any one has done this, please let me know as I was not able to locate anything with the "search" button.
Thanks!
-Shawn
thetaxguy is offline   Reply With QuoteReply With Quote
Old 12-22-2008, 10:39 PM #2
shuly's Avatar
shuly shuly is offline
Member
shuly is on a distinguished road
Member
shuly's Avatar
Re: Winch install w/o aftermarket bumper
Quote:
Thanks!
-Shawn
I am not sure how you would do this. This would definitely require some fabrication. The winch has to bolt to the frame of the vehicle. With a bull bar that is easily done. W/o something that is bolted to the frame, that you can bolt a winch to...I haven't any idea how w/o custom fabrication that you could do this.
__________________
My Rig: 2007 Limited V8 (Nautical Blue) | Front Lift & Sliders: Downey Kit | Rear Lift: OME 896 (Heavy with Nitro Sport) |Skids : BudBuilt | Bullbar : Shrockworks| Winch : Warn 9.5XP Amsteel Line | Lights : PIAA 580s | Tires : 265/65 BFG TA/KOs on 18" Stock Wheels | Audio : VaisTech Video iPOD Kit for Factory Nav | Newest Addition - BajaRack | June T4ROTM (Thanks guys!)
shuly is offline   Reply With QuoteReply With Quote
Old 12-22-2008, 11:24 PM #3
4runr30's Avatar
4runr30 4runr30 is offline
Member
4runr30 is on a distinguished road
Member
4runr30's Avatar
This has been done in the past by a company called Safari Gard, they are out of CA. Do a search for a member of this forum, xpdnrunner. He owns one of the few T4Rs that the company decked out for the television series Global Extremes. I did a search him earlier tonight after reading a thread on another site. If that doesnt turn anything up do a search of my threads, my first thread was on how to mount a winch behind the stock bumper, someone had posted a pic of this mod. From what I have read Safari Gard is reluctant to do any one time productions without a large sum of money. I have heard of people mounting a Warn winch plate behind the bumper and mounting the winch to that. Let me know what you decide to do, it is a mod I have been interested in since day one. The only thing holding me back is the $ involved to make this mod happen. Here is an article on the Global Extreme T4Rs that were released Global Extreme T4R
__________________
2017 Toyota Tacoma TRD Sport DCSB
Previous
2011 Toyota 4Runner Limited 4WD
4th Gen 4Runner SR5 4WD
3rd gen 4Runner Limited
4runr30 is offline   Reply With QuoteReply With Quote
Old 12-23-2008, 02:07 PM #4
thetaxguy's Avatar
Member
Member
thetaxguy's Avatar
Quote:
Now that is some good information. I will be calling Safari Gard after the holidays to discuss the possibility of a group buy...
However, I have been looking into the WARN universal mounting plates. I need to determine if there is sufficient space behind the bumper cover for this type of setup. Sometime during the holidays I will slow down and take some accurate measurements to test the feasability of this approach. If it does not seem reasonable then Safari Gard may be the only way to go...
-Shawn
Old 12-24-2008, 03:34 PM #5
Mabuse Mabuse is offline
Member
Mabuse is an unknown quantity at this point
Member
You could always add a front trailer hitch reciever, and then mount your winch to an accessory that fits the reciever. The advantage of this is that you don't have to drive with the winch all the time, just put it on when you need it. It does F up your approach angle though.
__________________
Proud owner of a 2006 Toyota 4Runner Sport V6 4x4 white w/ black interior
Mods:
- Baja Rack Mule cargo rack
- 265/70/17 Goodyear Wrangler Silent Armor LT
- Differential breather
- White color keyed grille
- WeatherTech floor liners
Mabuse is offline   Reply With QuoteReply With Quote
Old 12-25-2008, 11:07 PM #6
davefisher davefisher is offline
Member
davefisher is an unknown quantity at this point
Member
Quote:
This would've been my suggestion as well.
__________________
'03 LTD V8 4WD | Revo 2
davefisher is offline   Reply With QuoteReply With Quote
Old 01-21-2009, 05:07 PM #7
Photog3's Avatar
Photog3 Photog3 is offline
Member
Photog3 is an unknown quantity at this point
Member
Photog3's Avatar
It would take some fabrication; but it should work.
What you want to do, is have a Warn winch plate attached to the underside of the cross-bar, behind the bumper. This cross-bar is not strong enough to support the loads a winch can create. Have a pair of steel plates made, with 6 holes, to match the fastener pattern where the bumper attaches to the frame. Sandwich each of these plates between the bumper and frame, and bolt it back together.
Now, fabricate the necessary structure to connect the Warn winch plate, to these two frame-plates. You should be able to make all the parts from flat, 1/4" steel plate material. Use cardboard to mock up the pieces, cut out the steel, grind and file to fit all the parts, then have a welder bring it all together.
This should put the winch just behind the lower grill, in the bumper. You can also fabricate any necessary pieces to hold the farelead out front. This can take some heavy side loads too, so don't skimp on this part either.
__________________
Brian
http://i125.photobucket.com/albums/p...8E1457slim.jpg
2004 Sport V6, Build Thread, OME, SpiderTrax, Goodyear 275/70R17, Super Sliders, Scion radio, CB,.......
Photog3 is offline   Reply With QuoteReply With Quote
Old 01-21-2009, 06:33 PM #8
thetaxguy's Avatar
Member
Member
thetaxguy's Avatar
You must be reading my mind. I have been taking measurements and cutting cardboard off and on during the weekends. Hopefully right after tax season I will be able to have a welder build the prototype.
__________________
-Shawn | 2010 Xterra - 4X4 "The Panda #2." Aka, "The #2."
--------| 2008 BW UR - 2WD "The Panda" (Sold)
SoCal 2WD Trail runs: http://www.toyota-4runner.org/so-cal...tml#post537475
4th Gen Stuff for Sale: http://www.toyota-4runner.org/classi...tuff-sale.html
Old 01-21-2009, 08:32 PM #9
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Senior Member
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Senior Member
Kmvreter's Avatar
Since you are planning to fab something, consider this.
Search for user twfran who added a front receiver from HitchesOnline. Make your own to do the same type of thing but different. Turn it around ("upside down") and come over the top of the frame. You get around the approach angle by having the receiver come out the bumper where the plate is, not below it. Then you have the advantages of a removable hitch and not worrying about fitting it inside. Use the receiver for a custom plate holder when not in use and it will look stealth.
__________________
__________________
'04 SR5 V6 4x4 Galactic Grey Mica. Delivered 03/17/2004. Link to my mod list in posts 7, 8 & 9 of this thread: http://www.toyota-4runner.org/showthread.php?t=21354
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
``````````````````````` The battle begins at the end of your driveway... Game On! "Car!"
Kmvreter is offline   Reply With QuoteReply With Quote
Old 01-23-2009, 12:32 PM #10
boston_kevin's Avatar
boston_kevin boston_kevin is offline
Senior Member
boston_kevin is on a distinguished road
Senior Member
This is the thread you are talking about...
http://www.toyota-4runner.org/showth...threadid=37016
boston_kevin is offline   Reply With QuoteReply With Quote
Old 01-23-2009, 12:42 PM #11
thetaxguy's Avatar
Member
Member
thetaxguy's Avatar
I don't think so. In his response he said that the trailer hitch would come out behind where the license place would be.
__________________
Old 01-23-2009, 01:08 PM #12
Senior Member
Senior Member
Yes, but I think if you were going to fab something, you could use his installation as a reference for the frame you would need to fab out to attach a winch to the frame.
Old 01-23-2009, 01:35 PM #13
Kmvreter's Avatar
Senior Member
Senior Member
Kmvreter's Avatar
boston_kevin, thanks for posting the link.
Like he said above, and what I was trying to say originally, use the HitchesOnline receiver as a reference to fab your own. Go to their site to find the .pdf document that shows the hitch and how it mounts. Use this as a starting point. One thing I would add to the fab job is side gusset plates for added strength like those used to attach the framework in the aftermarket ARB bumper. HitchesOnline comes out down below the bumper so fab it the other way "up" to come out behind the licence plate to improve the approach angle. This is roughly the height where you would be if you mounted the winch inside the bumper. How high were you planning on mounting it and where were you thinking of coming out with the lead (in the upper front grill?)
__________________
__________________
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 01-23-2009, 02:43 PM #14
thetaxguy's Avatar
Member
Member
thetaxguy's Avatar
Nope. Right behind the license plate.
__________________
Old 08-17-2009, 10:04 PM #15
KrazedJD's Avatar
KrazedJD KrazedJD is offline
Member
KrazedJD is on a distinguished road
Member
KrazedJD's Avatar
I am deeply interested in this, I am thinking of adding a brush guard down the road, but a winch would be more useful off the bat. Also I think the look of the winch coming from the license plate area would look completely amazing.
KrazedJD is offline   Reply With QuoteReply With Quote
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hella 500 floating front bumper mounts...(install pics) momo.75 Engines / Suspension / Wheels / Tires / Audio / Accessories 146 10-16-2016 12:46 PM
Rear bumper build and Front bumper install ADH8796 3rd gen T4Rs 25 03-09-2016 03:43 PM
Lucrum Stock Bumper Winch Mount x67934 5th gen T4Rs 90 06-13-2011 03:52 PM
3rd Gen Rear Winch Bumper jimbob394 3rd gen T4Rs 3 01-17-2010 01:43 PM
Front bumper bent up, new light install ? skywalker1020 Classic T4Rs 4 04-24-2005 10:37 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
