5th Gen Wheel & Tire Thread
Discount Tire 100 off 400
Just jumped on Ebay to browse and saw that Discount Tire is once again running $100 off $400. At least on the mk6s i picked up during the Labor Day deal. Maybe that will help someone out. Hoping to get mine on this week.
Hi guys, looking to get my wife some wheels and tires for her 2015 4 runner for Christmas and have never had such a hard time finding out what fits.
Truck is a 2015 SR5 4WD. Stock Suspension. Stock 17's
Looking at a set of 17x9 -12 with 265/70/17 AT tires.
Stock looks to be 17x7 15 (or 17x7.5 15) So the wheels I am looking at will give a little more clearance inside but bring it out almost 2 inches. Should I worry about rubbing when turning? We are definitely not going to be putting a lift on it.
Thank you for any insite!
I would look for rims that are 17x8 0mm or -10mm offset. In my research/readings on this forum 17x9 -12 may have some fitment issues at stock height.
Level8 MK6--discount tire
any of the wheels by FNWheels/SCS
those are the popular rims
Also, the stock sr5 rim i think is 17x7 +15mm offset.
My Terra Graps have been great but nearing end of life. Debating on going to the Trails, however I'd like to consider any other recommendations.
Curious from those who may have run both as to the additional noise produced from the Trails.
On edit: Guess I need to consider the "Ridge" unfamiliar with this model.
Has anyone ever redone the stock Trail wheels in black? I don't mean just PlastiDip or something like that, but a properly done powder-coat job. I'm not a fan of silver or machined aluminum, but while I was washing the truck this afternoon I started thinking about what they might look like all black..
Will this wheel fit with a 2.5 inch lift spc upper control arms and stock tire size .
Looking for 18x9 Sizes
I have a 2016 trail with a 3 inch lift. I am purchasing 18x9 Fuel Nutz rims and i am looking for sizes that have little rub and would not require any trimming. Any help?
Im surprised there aren't more here showing off their wheels. Cmon guys! I need some more examples! lol:hungry:
not a common choice on the forum, MB TKOs with Chaos center caps wrapped in 285/70/17 General Grabber AT2s. No lift yet.
My 285/70r17 Yokohoma Geolander A/T G015s don't rub at all with my 2015 SR5 with stock wheels (7" wide) and 3" toytec kit. I didn't expect that...
I understand that. But [MENTION=131471]CF_Machete[/MENTION] is running no lift. Not sure on the back spacing on those rims. But that's a good fit!!
I actually mounted up the 285/70s prior to the lift.. No rubbing when turning, but I wouldn't want to do any flexing, as there would likely be rubbing in the upper portion of the wheel well.
And rubbing??
rubbing in left reverse at full lock and mild rubbing at lock with flex. Daily street driving is no issue, but the fender liner mod is a band-aid. I'll have it lifted shortly.
The MB TKO rims are 17 X 8.5 -6
Went with Toyo ATIIs in stock size. I had the Toyo Open Country RTs on my Raptor so I stayed with the brand I knew. 20170112_173313.jpg20170112_173319.jpg20170112_173430.jpg
XP wheels
I've had my XP package for 2 weeks and really love these wheels.
I'm about to lose my mind trying to decide which rims to go with.
Torn between Method Nv and SCS Stealth 6
Stealth 6 is -10 and NV is +0
leolediola
