5th Gen Wheel & Tire Thread
I'm leaning towards the Stealth 6 but of course they are out of stock in my size :/
I love methods but I know if you decide to get them, you should also invest in some hubcentric rings to prevent potential vibration. 108 to 106mm.
Would mind elaborating on this. I am new to this Forum and my 2016 4Runner (Yay!). I am not familiar with the problem and the suggested fix.
Thanks!
Thanks!
Toyota's have hub centric wheels. Methods are lug centric wheels with a 108mm bore, and Toyota's have a 106mm hub.
While 2mm doesn't seem like much, some people have reported vibration while driving with Method wheels. Many companies make rings to sit behind your wheels that will convert your 106mm hub to a 108mm hub, and therefore should eliminate any vibration issues with Method wheels.
Good luck with your choice. Method wheels are sharp!
SCS is pretty responsive if you email them. They were out of the F5s I am getting and let me know as soon as they were in stock.
Ended up going with VTX Outlaws!
OK Here's Mine
- NV Wheels 17x8.5
- BFG Ko'2s 285/70/17
- Toytec Boss Kit with 2.5 reservoir rear shocks, Total Chaos UCA's
- Photo(s)
- Body mount chop: No
- Do your tires rub: Not after the lift
<a href="http://s1024.photobucket.com/user/joshlee1203/media/IMG_3089_zpsgigw2j0q.jpg.html" target="_blank"><img src="http://i1024.photobucket.com/albums/y305/joshlee1203/IMG_3089_zpsgigw2j0q.jpg" border="0" alt=" photo IMG_3089_zpsgigw2j0q.jpg"/></a>
I have a 2017 TRD Pro and am considering putting a set of hub centric wheel spacers to give it a more aggressive look. Does anyone know how thick I can go without rubbing?
Method wheels 17x9 -12
BFG KO2 285/70/17
3" Toytec stock UCA's
Body mount chop: no
Do your tires rub: yes trimmed mudflap and moved over inner fender with some trimming on bumper next to inner fender no rub now.IMG_0251.jpgIMG_0252.jpgIMG_0253.jpgIMG_0254.jpg
BFG KO2 285/70/17
Body mount chop: no
Do your tires rub: yes trimmed mudflap and moved over inner fender with some trimming on bumper next to inner fender no rub now.View attachment 242447View attachment 242448View attachment 242449View attachment 242452
Refreshing...someone without matte black wheels. They look good.
2016 SR5P 4WD Super White
Bilstein 5100 @ .85
Nokian Rotiiva AT 265 70 17
Opinions
Hey guys. I just did the 6112 and 5100 setup on my black '16 TEP. Now...I need wheels. I want to stick with a 265 but on a 17 x 8 or 17 x9 wheel. It's got to be hub centric and not too heavy? Any advice on style and colors? Right now...I'm between the fn countersteer type x's in black or the Stealth Ray 10's in the dark bronze matte. What do you guys think?
Same issue - did the fix work?
Previous posters have stated that the 265 70 R17 did not make a difference vs. the stock limited pizza cutters. In my opinion this is not true at all. My 265 KO2s completely transformed my 2015 4x4 4Runner Limited into a much meaner, cooler vehicle. Now to contemplate a lift.
Note: Even with the 265s I do get a very slight rub on the front tires when in reverse. Looks like it is rubbing on the part of the plastic wheel liner closest to the bumper and should not be hard to heat up and deform.
I'm getting the same rub on my 2016 Trail with the same tires. My wheels are American Racing AR-172s. Any luck with the heat and remold, or did you have to shave the lower edge of the front bumper? BTW, mine is rubbing only on the driver's side and only when backing up with the wheel cut to one extreme direction (clockwise).
IMG_2616_zpshinbvmzs.jpg~original
Stock suspension
17x8 -10 MK6
P265/70/17 Falken Wildpeak AT3W
Had to remove the front mud flaps and push the front fender liners in and trim the bottom lip of the front bumper to eliminate rubbing.
Hey guys, Yes I have read thru the entire 20 pages of this thread. Yes i may have missed it, yes i googled it, and no i haven't figured out an answer.. Sorry in advance... I had every intent on lifting and going smaller in wheel size with an all terrain tire but for my job that is not practical now.
I have a 2014 LE stock suspension with the factory 20" wheel on Pirelli Scorpion ATR 275/55/20. 30k + miles on the tires and they have been great and have plenty of tread left. I want to replace the factory 20' wheel with a something different but keep the tire.
The wheel i have found is a 6x139.7
20" x 8.5" with +30mm offset, 106.1 hub bore
The factory wheel is 20"x7 with +15mm offset and 106.1 hub bore. (unless i am wrong)
My question is with the +30mm offset and the 275/55/20 tire. Per the calculator on wheel-size.com it is telling me this Tire is 15 mm closer to suspension components. Rim is 34 mm closer to suspension components. and Rim offset is more than OE, so brake support will be closer to the rim. Make sure they are not touching.
The offset seems high but being the wheel is 1.5" wider than stock i don't know if it will rub or not.... I cant find anyone on here that is running a 20" rim with an offset that high on a factory suspension...
Any ideas?
AJ Cat
