5th Gen Wheel & Tire Thread
4.5/3 lift
Wheels: Micky Thompson Sidebiter II 17x9 0 offset
Spacers: 1.5 wheel spacer, cheap ebay stuff
Tires: Falken Wildpeak AT3W 285/70/17, E
Suspension: ICON Stage 1, with 3" overland spring. With some JBA UCA. And two 1/4" shims to add another 1" to the 3.5 from Icon. So that make a 4.5" front and 3" rear lift
Body Mount Chop: None
Tire rub: only rub when I reverse. No rub at all on road or off road.
Trimmed: about 1/4" from front bumper.
Mud flaps: Removed fronts for now, they were rubbing little bit.
Yesterday I finally upgraded my wheels and tires from the stock SR5 wheels and stock size BFG AT KO's. Couldn't be happier with the outcome!
Thanks @VTXOffroad for the wheels, they look badass.
Specs:
VTX Offroad Viper's 17" x 8.5", Satin Black
Toyo Open Country AT2's LT285/70/17 Load Range E
How does it look when not on a high-lift jack?
Wheels:
Stealth Custom Series SR8 in Matte Dark Bronze
17x8.5"
ET-10
BS/ 4.30"
Tires:
Cooper Discoverer ATP
285/70/17
Lift:
Toytec 2.5." Front spacer
Toytec 2" Superflex Springs
Modifications to avoid rubbing:
Removed front mud flaps
Trimmed corners of front bumper
Pushed fender liner forward about 3"-4"
MB vortex 17 inch wheels with duratrac 285's. Lifted and super sliders from Rocky road.
Used 3dcarstickers dot com for replacement acrylic center Toyota decal ilo the MB center decal. See my post on this in the "what did you do today thread"
Thanks,
J
Sent from my LG-D850 using Tapatalk
I'm looking to do a 3inch lift with 285 Nitto Ridge Grapplers. Do you get any rubbing on your daily drive?
18x9 +0 Volk TE37 on 285/65/18 Toyo Open Country AT2 Extreme
Beautiful setup!
How are you still running your front mudflaps without rubbing? Did you have to cut a hole in them or did you do the heatgun trick?
Hope this works, I found this picture on google. Can anyone tell me what these wheels are? Perhaps factory sr5 wheels painted? Thanks
You need to trim the front bumper overhanging lip at an angle at the very bottom....about 3 inch length of that end are gone...
and the front mud flaps have to go.....
Next I made sure to have alignment tech keep the rear most eccentric washer in the middle and adjust the front eccentric to spec for camber...caster will be out but acceptable.
Before leaving alignment I did full turn of the wheel and I had about .5 to .7 inch gap at the rear and about .4 to .5 inch gap at the front bumper after trimming.
J
Decided to do the lift.
J
Thanks for the help. I decided to get the lift and stay with the 285/70/17 tires. I'm hoping to pick it up tomorrow and I'll post some pics.
Does anybody like ''shiney'' wheels besides Me?! Method ''Standard'' and Mamba M-14 ''Machined'' are my choices.
I am not a huge fan of them but that's whats so cool about runners and wheels, everyone has their own look. I think they look sick on a Tahoe or something, I just wouldn't throw them on my runner. To each their own! :peace:
Here's my SCS F5. I love them! The only wheel I considered and I got them on the first attempt .
Just changed over to FN FX wheels with 265/70 Toyo ATII's. Really made a difference and Dustin was great to work with.
BillM777
