5th Gen Wheel & Tire Thread
Wheel covers/Imposters
Anyone know where I can find black SR5 wheel covers/imposters? Recently purchased a 17' and came with black plastic wheel overs over the alloys. One came off and was run over. having a very difficult time finding a replacement.
Honestly I would just get em powder coated and not worry about a cheap hub cap.
But if you wanna stick with it I’d check eBay
SCS Stealth 6 17x8.5 on 285/70/17 Duratracs
Wheels: SCS Stealth 6 17x8.5 4.30BS -10 Offset
Tires: Goodyear Duratrac 285/70/17, D
Suspension: King 2.5" Extended Travel Coils with Remote Reservoirs
Body Mount Chop: None
Tire rub: Slight Rub on body mount in Reverse at full lock and moderate Rub with any Flex
Fenders: Trimmed about 1/2" on that bottom front lip
Mud flaps: Removed fronts
Very nice! I had these on my 2012 Tacoma. Now I`m running the 17` SCS F5`s. I`ll post some pictures later on.
Can anyone tell me what tire size this rig has? Found the pic online and fell in love! Exactly the look I’m going for. I don’t know who’s this is, so if you see me driving around in a 4Runner looking exactly like yours, please take it as a compliment that you built my idea of the perfect Runner!...
What CB antennae mount is that??
Wheel: KMC XD 131. 17x8. 0 offset, 4.5 backspace.
Tires: BF Goodrich T/A KO2. 265/70/17, E.
Suspension: Bilstein 5100 shock at all four corners. Front shocks set at 0.85.
Body Mount Chop: No.
Tires Rub: Tires rub front fenders close to full lock in reverse.
- OEM Lexus GX460 F Sport PTR5660120 - 18x7.5 - Almost 5" Backspace - 20mm Offset - No Spacers
- Toyo Open Country A/T2 275/65/18
- Bilstein up front at 1.75" IIRC - Dobinsons rear springs (can't recall which model right now)
- Body mount chop - No
- Do your tires rub - No; I obviously didn't go big enough.
Maan!,
I really like the white out lettering with black wheels on the magnetic grey. Looks sick. Traded in my 13 LE for a 19 ORP in mag.grey and this is the look I want. Good Job picking the white letters over black
Falken Wildpeak A/T3W LT285/70R17
Mamba Offroad M23's -12 Offest 4.53 Backspacing
3" BDS Suspension
I have a little bit of rubbing at full steering lock but will just need to trim the very bottom of the inner fender. I also took the front mud flaps off. Other than that I love the setup. No serious trimming needed and the Falkens have been great on and off road so far.
3" BDS Suspension
Have any more pics of those sliders? They look to be able to be used as step
not really right thread for this but [MENTION=313761]victoryrunner[/MENTION] looking at the pic i don't think the sliders are designed exactly right. someone maybe [MENTION=118321]Jetboy[/MENTION] ? posted some good info recently about slider design that i hadn't considered before.
i believe the gist of it was, the main inner square tube should sit under the pinch weld running along the underside of the rocker. when the weight of the vehicle is dropped on the slider and it flexes it will disperse the force along the length of the body rather than in 2 localized spots where the support arms contact the pinch weld.
Sorry if that picture wasn't clear. Here are some more photos.
They don't touch the pinch weld. They are frame mounted and have 3/4" gap between the slider and the pinch weld to allow for some flex on a full weight drop. They should never contact the pinch weld.
Victory 4x4 is a sister company to JcrOffroad who has been making Jeep armor for 15+ years.
Let me know if you have any more questions about them.
VenomRex Wheels
Does anyone know anything about/have the VenomRex VR-602 wheels? I love the look but can't seem to find much info about them on the forums.
Even the greater internet is only really talking about the wheels on Raptors and trucks even though the VenomRex product page says they will fit 4Rs and Tacomas.
5th Gen Tire Recommendations
All, First time 4Runner owner. It is time to put some new tires on my 16 4Runner. I want to put bigger/AT tires on it. What do you all recommend. Stock tires on now with 20" rims. I plan to at least level it in the future just not ready to do that. Going to put some new rims as well but haven't found what I am looking for.
So looking for feedback from the group.
Thanks in advance.
BillM777
